Originally Posted by
Graham yes they have same 24mm pin size as pinto. it is a bronze bush, true diesels dont rev but they put way more load into components, so i cant see why the OE bush would not be upto the job.
Pistons are already here, im putting the same pistons back in, they are yb with very thick crown to allow machining to however you want them. so i will have to machine a chuck off the crown, i am un decided as to whether to put valve cutout back in or not, if a fit something like an RL31 it wont need them, but it probably wont hurt to put them back in even if not needed. in fact putting them back in would give a bigger safety margin in case of a missed gear, or allow me to swing the timing on the dyno without a care so to speak. not to mention i need to drop the compression by about a ratio
