need info for new sump pls
Currently fitted to 2.0ltr silvertop i need a replacement as this has been ground down and is leaking.
Any help appreciated its currently fitted to a tiger caterham style kitcar
Thanks in advance
Re: need info for new sump pls
Surely easier to cut the bottom off, raise it 15mm and reweld a new 10mm thick plate on for wear resistance? Finding another that won't need work is a long stretch - niche item in a niche market!
drain plug is asking for a ripped sump too ![Embarrassment](/images/smilies/blush.gif)
i made a flat one for a westfield using a 2 piece blacktop sump. the lower steel section can be re welded. pics on one of my threads somewhere - fair bit of work involved tho.
