Long time forum lurker here... figured I'd contribute something, ask a couple questions & share my last dyno run.
Modifications are:
2.0 Pinto
Ported Head with oversize inlet valves (I forget the size)
Head has been skimmed a bit, but not a lot. I forget how much exactly hence the CR is not known. I believe it's around 10:1 or so.
Kent GTS1 camshaft w/ vernier pulley, matching Kent valve springs
Twin 45 DCOEs - 62mm trumpets, 36mm chokes, 140 mains, 155 Air correctors, F16 Emulsions, 55f9 idles, 4.5 Auxiliary Venturi, 40 Pump Exhaust Valve, 45 Pump Jet, 2.00 Needle Valve
Standard fuel pump w/ Malpassi fuel reg set to just under 3psi
4-2-1 headers into 2 1/4" exhaust
Burton Electronic distributor w/ matching coil, 30 degrees timing all in
Running 98 octane fuel
Run 1 was done before run 2 where I'd added the vernier, re-timed the cam and swapped out the points dizzy for the electronic one.
119hp @ wheels, 116 ft/lbs @ wheels
163hp @ fly & 159 ft/lbs @ fly (estimated)
Keen to hear some thoughts from those more experienced engine builders/tuners here about anything that stands out from the graph and specs, room for improvement, or any comments in general. Would like to know the best place to get the next 10-15hp from. I know this is very difficult to say without knowing CR as it's likely where the gains would lie, so maybe taking a head off and working that out is the next step.
Questions:
I'm curious about my 140 mains and 155 air correctors, it seems like most engines with similar specs I've seen have bigger mains and airs. From my understanding the bigger your mains, the bigger your airs need to be, and vice versa. Would I be able to go up in mains and also airs to potentially make more peak power, or is there more to it than this. The tuner said we were on the verge in his mind of needing to go to 145 mains, but he didn't have any comments on the airs too.
I'm also curious about peak power being just over 5500rpm, I'd have thought it'd be higher up the rev range around 6500 given the camshaft. What keeps it sitting at 5500rpm? Choke size in the carbs? Would 38mm chokes make slightly more power at the expense of the mid range?
I'm also chasing a clean progression between the idle and mains circuits. I have 55F8s originally but changed to FF59s with better results. The 55F9s are great when the engine is cold, but once it warms up it runs worse, even after adjusting the mixture screws. Considering going to 60F8s to see if that makes things better or worse. Right now there's a stutter at around 2500rpm if you're moving at a moderate speed in first gear, and it can splutter a bit between gear shifts. Once the car is warmed up and I'm sitting in traffic for example, this is where the progression seems to be worse. Will the engine be running richer once it's hot?
Page 1:
Page 2:
