RS1600i powered by Garrett T3 but now I need a stronger clutch. Who can help?
I`m looking for a stronger clutch because my RS1600i tuned with the Garrett from S1 or S2 Turbo Escorts now has 220hp and 290Nm. Who knows a solution for me and my RS. The problem is the RSi has a smaller flywheel and this one cannot be changed because it has one thooth for the sensor to the ignition Box.
Im very interested for your answers
A lot of greetings from Germany
Peter
Re: RS1600i powered by Garrett T3 but now I need a stronger clutch. Who can help?
i assume youre still using the twin coils and ecu? how have you altered the ecu for the correct timing for turbo use?
the rsi uses a 200mm flywheel as standard, a decent heavy duty s1 clutch should take the power you have without too much of a problem, have you checked to see if ap do a 200mm paddle clutch?
