Has anyone had problems starting their diesels over the past few weeks of cold weather?
Monday morning my little 205 Pug diesel started on the button as usual but then stopped after about 20 seconds and refused to start, cranked over fine but wouldn't fire, I was late for work so gave up and jumped in the van.
Had another go after work, I loosened the fuel union off the injector pump and pupmed the fuel primer pump on the fuel filter and diesel poured out of the hose so i know that the fuel was flowing freely. I reconnected the fuel union and bleed the fuel througn and it started fine, left it to warm up for 20 minuets and turned it off, and it restarted first time as usual. Great. But this morning it refues to start again !
I checked under the car to see if there was any diesel leaks, but nothing. I have been told that sometimes a fuel line on the vacume side of the fuel pump can crack and nothing will leak out as it's under vacume, all it does is draw a little air in and is not noticable when driving, but when you turn the engine off, the hole allows the fuel to run back to the tank and when you go to start it's as if you've run out of fuel, prime the fuel filter and it starts.
Could the extreme cold weather have caused a fuel pipe to become brittle and crack. I know there are 2 right at the back of the engine block that connect to the fuel preheater manifold.
Anyone have any other suggestions ?
