I am looking for a cheap Pinto distributor blank or old Distributor.
Need due to using a coil pack..
I may well have an old dizzy in the attic, if I have then you can have it for the cost of P&P if you dont get sorted
Will look tomorrow after uni.
Ste
Will she ever see daylight.............:-(
Are you dry sumping it as well? Otherwise you need to have an oil pump drive so it's best to use an old dizzy ;-)
sorry didn't look yet as I had to go to work straight from uni for my 12 hour nightshift and here I am still.will look when i get up today and post up a reply sometime in afternoon
put a core plug in the hole
just back from Calvin Harris , did look in loft earlier and do have an old dizzy. Just giz a shout if you still need one
