I would rather be shagging me tyres........
Well done Paul, Its something different on here but still rallying so it get my vote!
Darrians have really grown on me the last few years, but not sure i fancy getting in one for an event mind you! Is that a T9 Darrian?
Thanks Paul,
Yes shes a T9
A bit of history of prevoius owners below, I have not heard of any of them I will prob be the first to really drive the car hard
Peter Mathews - Cairfili Wales
Grant Roberts - South West
Steve Furzland - South West
Damian Cole - South Wales
Geraint James - Cenarth Wales
Dennis Patterson - N. Ireland
John Stafford - Wexford Republic of Ireland
Yeah ok Paul - big boots to fill!!What engines have been in it then over the years?
I didn't know Steve Furzeland had a Darrian.
So today has been busy... I have collected most of my bits together and taken it all to its new tempory home !
As my good friend Andy Fraser at Promotive exhausts will be taking the major part in the engineering and fabrication side of the install.
We have
Darrian T9 rolling shell
Honda S2000
RED throttle bodies dry sump system Race tech ECU etc etc
Hewland NMT
So its just a case of throwing it all up in the air and hoping it drops in the right place
Hi Pugrwd,
You have stolen my dreams. Almost..... I wanted to fit a Turbo S2000 into a Darrian. I've bought a Eurocar Mondeo (space framed Mondeo from speedway classes) to fit the turbo engine in now.
Hope you can have a lot of fun with this super car.
BTW, a Zakspeed Capri is one of my other wet dreams.
I put Darrian into google to get some pics of what the car looks like and all that comes up is a porn star called Racquel![]()
Andy here. Paul, you've pretty much described the whole engineering process. Will be following similar principals as used on my Darrian but with perhaps less TIG welding and more MIG to cut down on time and cost.
Bellhousing to be machined from solid block of alloy using CAD/CAM method. Will post pics as it happens.
Please, next time come over so we can share some idea's. You where at approx 45 kilometers from my house. It was a Hewland box for sale? What company you where after in Belgium?
BTW, you can find S2000 bellhousing for the T9. Maybe you can fit these on your gearbox?
www.euroracing.be/index.html was where I bought the box from !
The car uses a transaxle so unfortunately that bel housing type is unsuitable, so we shall be making a bespoke item
Best of luck with it Paul
We will be keeping www.darrianonlinenews.com updated with news as you go along
What engine spec. will it be? Standard, tuned, turbo ?
I'm currently building one 2,4 Ltr S2000 on 2x 48 Weber DCO/SP (programmed ignition) for a customer and one 2 Ltr turbo engine which will be used in my own car.
Hi the engine will be standard 2ltr with dry sump system and racetech ECU so hope to see a little over 250bhp
Do you know of people using the atmo 2.4 stroker kits successfully in Motorsport ?
I'm sure Des Moore (Des Moore Race & Rally) in Ireland runs a 2.4 version.....see http://www.dmrr.net/
Cheers,
David
If you use the standard engine and throttle bodies setup it will even be hard to see 240 Bhp. Sure not 250 + . Sorry. I've build several years ago. Standard is less than 220 Bhp, with throttle bodies average was 235 Bhp. I used long trumpets to give it some torque because they really have no torque. But it answers well to inlet length.
I've never build them in 2,4 Ltr before but I will let you know what power and torque. Engine will be on 48 DCO/SP. Hoping to increase the torque.
http://raceenginedesign.biz/honda.htm
This is the set up of throttle bodies / dry sump etc I have..
Little bit about the 2.3 at the top
I know of a guy in the US that builds them up to 2.7 with 400whp for drag racers, that may be a bit extreme but you could build a reasonable 2.4 stroker with his rods, Mahle pistons (so they don't eat away at the FRM bores) and an accord K24 crank (with some machining); combined with cams and jenveys ~300bhp isn't that far off with decent torque as well. A few guys on the S2ki forum are running these strokers successfully in road and track cars.
The engine builder's company is called inlinepro, some valuable info on there.
2,7 Ltr, something new I can dream of.
I would never use the Honda cylinders in his original form. As a minimum, put thin slaves in them. Original Honda S2000 cylinders are like lottery. Don't relay on them. In the beginning we used Mercedes replacement slaves (a guess build to repair old diesel engines ? and still ready available and very cheap). Was working very well, even in my turbo engines.
Please note, if you replace the cams they get even more peaky. But maybe not be a problem when using a very close sequential gearbox.
I normally see 220bhp on std set up but have 2 cars running t/b's that give over 250. What they need is a cold air box for the intake , they hem-rage power with just the foam type air filter. The other area is the exhaust manifold, again if its wrong you will lose 30bhp.
Used to own a Darrian F9 some 20yrs ago , great car , and take it from me, very strong in an accident. Currently run a Davrian Dragon MK8 for my son.
Ah Vince I take it :-)
I have the RED race tech set up with the extra spacers on the throttle bodies as stated said above and my research finds these engines seem to respond to a good length ( bit like the girl friend ). Would you agree ? about the engine that is ;-)
Air box is something I have not thought about yet but thanks for the input.
Not really found much info on manifold sizes lengths configurations etc all I have found is people seem to think Honda know best and stick close to the standard manifold dimentions,
What have you noticed about good ones you see on the rollers ?
I hope not to find out how strong the tub is !
Cheers PC
Some years ago (I think 8 ? maybe longer) I have tested almost all inlet lengths to compare. I can check my dyno graphs and see what was working best for torque. I do remember we even tested silly long lengths. And inlet diameter was no bigger than 48 mm.
I also made a special exhaust system those days. It was a modular system, I could test any length, any diameter and any combination (4-1 4-2-1 in any length configuration again). So we could find the best exhaust length and diameter.
The engine was on the dyno for a very long time during that winter. We finally found a very nice torque curve (not as high as we found in engines like the Nissan 2ltr SR20) but much better as it came from Honda. Must say, I never saw 250 Bhp. More like 235, maybe close to 240 but sure not more.
I would never fit an airbox unless it is internal VERY big. It knock down pulse tuning when to small inside, just like as standard plenum.
Thanks ,
It would be good to see any Info have![]()
I can only go on what i have seen. Customer ran one in Ford Puma RWD and had brought a manifold from a Honda specialist . All i can say is it gave an increase. Yes the std one is very good and i know of a couple of exhaust specialist that have got it wrong trying to adapt conventional thinking to a manifold. It also needed some adjustment to the maps .
Same with the air box, the difference between foam filter and it, were significant enough,to make it more than worth while. Sorry i don't have any figures at home and am too busy to post at work.
Fits nice, keep working, still enough room, add some turbo's .......
I have no idea about the wiring. I've never used the original ECU.
No turbo's sorry the class I want to run it in means it has to stay N/A
I was joking about the wiring loom ..,,![]()
Try and get hold of Bruce Edwards in Scotland, he has run whats probably the most successful S2000 darrian in the country.
I have spoken to Bruce a number of times and really his car is the reason I changed my mind on my choice of engine !
I'l keep you informed about the 2,4 Ltr engine. Will post power graph when dyno tested.
