Should an ipod be able to play music through a pc ? I have two pc's but neither will play any tunes from it![]()
Cheers Wyn ...
Stuck in the 80's
Back in Black
btw, ear phones work fine ?
Cheers Wyn ...
Stuck in the 80's
Back in Black
What socket are you using to connect the iPod to on the PC? Mic or line in I assume?
it's much easier to connect it via a USB lead and use iTunes (or something that doesn't suck quite as hard) to play the music stored on it.
*edit* this should work OK
http://www.ipodsoft.com/site/pmwiki....layer.HomePage
http://escort.accelerator.org
You need to use the little program I linked to in my last post. When you connect the ipod to a PC it treats it like a hard drive, you need the software to interpret the iPod's file system properly!
