are they (2door saloon) all the same ?
sorry for the daft question...
Not exactly mate, there is a 'RS' shell called a type 49 shell which is a slightly strengthend shell, doesnt make much difference though to be honest.
And if you are that bothered by it there are kits to turn normal shells into type 49 shells.![]()
WWW.NTSAUTO.CO.UK
BERKSHIRE BODY SHOP
so basically a regular shell can be updated to a 49 at any time then ?
There is also an export shell as we know it in the uk, its kind of in between a std and type 49 shell for export markets, usually has type 49 shell top plates fitted to the inner wing and some other bits but im unsure as to what.
there are also various age related differences. bonnet hinges, bulkhead holes, rear shock mounts and god knows what else !
I thought the type 49 also had a bigger Tranmision tunnel ?
Nope just the autos i think.![]()
I have a export shell, it has the top plates plus inner, rear chassis strengthening and the bolts through the boot floor as std, no anti tramp bars but with a rear anti roll bar fitted as std fitment
The 68 models had no ARB and different rear suspension mounts.
Zetec Mk 1 Escort
Mk 2 X Pack Capri 3.0S (not a copy, the real thing)
Mk 1 XR4i
Mk 3a Fiesta Si
www.zetecescorts.bravehost.com
early modela had door locks in the handles, later ones were below the handle,also very early ones had different front suspension set up
Some things on early escorts:
Locks in door handles.
External bonnet release.
Washer jets on bonnet.
Heater dome goes to a point either side.
Compression struts (no arb).
Sticky out petrol filler neck.
Washer bottle on drivers side.
Rear shocks mounted on a bar.
Maybe a couple more things thats all i can remember.![]()
Zetec Mk 1 Escort
Mk 1 XR4i
Mk 3a Fiesta Si
Yup.
i only meant the 2 types of bubble
thats the pointy ones sorted.
Was the Twink built on a different shell again, Type48???
The loom splits down both sides on the early models as well. Mines an F like the one pictured.
Zetec Mk 1 Escort
Mk 1 XR4i
Mk 3a Fiesta Si
Rear fire wall is different to ... some of the floor pressings are different .. and the 'C' Pillar
type 49's are easier to fake than turning a late shell into an early one
my early shell also has the t49 rear spring front hanger skids
