Quaife 6spd sequential and other parts
Quaife 26z 6 spd sequential gearbox, was rebuilt by Paul Patrick in Galway before i bought it in may. Has done 2 single venue events with approx 120 miles with no issues, comes with a digital display and loom and i also have a 2 piece prop with a jaguar centre bearing and done the same 120 miles, this is a direct replacement for a type 9 box i also have a vibratechnics mount and gearbox xmember to go with it as well.
Ratios are
1st 2.39
2nd 1.69
3rd 1.34
4th 1.15
5th 1.00
6th 0.87
Recent upgrade to a 60g hence why its for sale
£3600
Also a Hi Spec 275mm big brake kits for 13s
pair of calipers with mounting brackets
pair of 2 piece discs and floating rotors
Set of green stuff pads which i only used for the road to and from mot station
Set of pagid Rs4-4 pads brand new
£700
Pair of 2 piece quaife shafts with atlas 16 spline ends to suit a 47" axle, come with flange ends assembled done less than 300 miles
£250
Tran x atlas diff 16 spline and i also have a pair of 18 spline side gears to go with it done less than 300 miles
£600
Pair of fully floating 2 piece shafts only bone about 200 miles 18 spline
£150
All being changed due to upgrading collection from plymouth preferred
Re: Quaife 6spd sequential and other parts
I'm also after a sequential gearbox, but what's the difference between yours and a 60g ?
as far as I know, 60g can take more torques & power, but does the shifting/operation far better than the old design ?
the 60g is better obviously but at twice the price its to be expected, the 26z i believe is rated at 250bhp compared to the 60g at 375bhp
cant really tell you much more other than it worked well for me on 2 single venue events with no issues, its ony due to a new job with good money has given me the chance to upgrade
Evening mate I'm the guy who works with the bloke that text you today about the gearbox any chance I could come and have a look at box? My number is 07805067751 if it's easier to text/call
Cheers Nige
Box now sold brakes now £575
Good afternoon!
Just to confirm that the 6sp sequential box has sold has definately sold?? Thank you!
Yes it was collected last week
