anyone use Mk2 escort Rally Design Pedal Box?
Did anyone have to cut any of the threads on there cylinders as ive fitted mine and they seem very high off the floor?
i have phones Rally Design and they said shortening of the threads is not needed. has anyone had any expieriences?
Re: anyone use Mk2 escort Rally Design Pedal Box?
Yes, seen that before with RD pedal boxes.
i dont mind cutting it down but they said it dont need cutting down which makes you think what have i done wrong?
I had one f--king hideous thing now have a Gartrac one never looked back at least you didn't have to use a step to use it
I'm saving for a gartrac one ATM due to the issues I've heard other folk having, I'd rather bolt it in bleed it and get the bias set up with minimal messing around
Them pedal boxes from RD are cheap for a reason you get what you pay for
I would not rate rally design stuff for hard competition use, I had one of their pedal boxes and it was flexing under heavy breaking in the dry and their steering arms bend far easier then genuine ones.
Hi
I have Rix Engineering ones in stock if you are interested, excellent quality using original pedal as part of the conversion. Also only use genuine Girling Master Cylinders.
Price and pictures are available at the link below:
http://www.tjmotorsport.co.uk/products.php?cat=10668
Regards
Tim
Any chance you have a contact number or email for the guy that makes them as I could do with getting some components off him so I can make a custom one for my Chevette?
Could you post or message contact details for the floor mounted pedal box, we're looking for one for a space framed race car & it looks very much like what we need.
Does it come with bias bar & cylinders ?
David
I got screwed over from RD too often will never use them again Bought billy inserts for the front no name on them apparently the same bur from china. But on the receipt it says bilstein inserts. NEVER AGAIN
The Following User Says Thank You to stanook For This Useful Post:
