rpm
Hi guys i am looking for some help i need to find a true rpm signal on a mondeo 2004 1800 zetec i have tried all the normal places and the ecu's but cant get a true reading help please Rab as am stuck
Re: rpm
what you actually trying to do?
Re: rpm
Hi m8 i am fitting an lpg kit but it needs a true rpm signal and we are baffled all help is welcome Rab
Re: rpm
tried all the pins on the both ecu's under the dash on the drivers side but none of them worked, unless that one you mentioned is else where
Re: rpm
using a couple of diodes you can get a signal off the coilpack
Re: rpm
sorry m8 bit dum when it comes to this sort of thing, what exactly do you mean?
Re: rpm
cheers m8 will see what my freind thinks he fits these for a living and he has never had this before thanks again Rab
Re: rpm
well guys a tried the diodes and my lpg is still not coming on so i dont know if they work or not, thanks anyway cheers Rab
