What power and torque are you after what compression is the engine at and camshaft are you using I've built a 2.2 litre same as yours I'm running a newman p5 camshaft cheers mario.
On a 2 litre bottom end I'm at 180 flywheel hp hoping for more with the 2.2 litre bottom as I'm going to use the same head
I've also got an extra 20 cfm at mid lift so I'm hoping for more hp aswell cheers mario.
Bore is at 92mm so I don't have to touch the combustion chamber so compression will change from 10.8 to around mid 12 as old block had piston down 20 thou from tdc new block now has piston 10thou out of block at tdc to increased compression .
Standard crank been offset grind to suit custom rods and pistons
4mm on crank and pistons are 92.5mm
According to my calculations that gives you a cylinder capacity of 550cc, giving you a total of 2220cc. Those figures are with a 92.5 bore and 81.9mm stroke crank.
4mm on overlap.
Yes I got .500 lift on inlet and exhaust valves
