Results 1 to 6 of 6
Thread: MX5 NC 6 speed adding a electronic speedo drive
    Spanner Monkey Darbo's Avatar
    Nov 2009
    Lancaster
    462
    decided to put a mx5 6 speed in my 2.3 duratec escort as the cossie t5 is whineing abit
    but after buying the box found that its speed sensor is just a blank and you need some hens teeth part to make it work
    so seeing as i just bought a lathe i decided ill have a go at making the speed sensor gear wheel
    the signal wheel mounts on the tail shaft using a 6mm bearing and circlip to keyway it in place
    i will drill between the boss i made trial and error untill i get the right depth so the circlip locates
    im planning to index 6 teeth on the gearboss but as i dont have a index wheel on my lathe and im very much a amature it will be out with the grinder to cut my teeth
    in the "to size" boss ,the easy bit was the sensor its just a mazda 3 wire sensor the box already has a place for it to bolt
    May 2004
    Norn Iron
    1,148
    Re: MX5 NC 6 speed adding a electronic speedo drive
    What does the box/car normally use for speed ?
    What sort of signal do you need for whatever speedo is in the car ?
    Nov 2009
    Lancaster
    462
    mx5 duratec nc normally take a speedo signal from the abs sensors
    they did fit the gearbox speed sensor on none abs supplied cars
    my car has a racetech programable speedo using a ford ka /fiesta speed sensor of the cable drive with a burton adapter in the cossie t5 box
    so it just needs a 3 wire adapter to mazda sensor from the superseal i had fitted to the ka sensor
    anyway the gearbox 6 tooth wheels done i balanced the mazda sensor ontop
    Dec 2019
    Rotherham
    12
    Very clever, I'm looking at mounting an abs reluctor ring onto the gearbox end of the propshaft and using an abs sensor for speed signal
    Nov 2021
    Llandudno
    Would you be willing for cash to make one to suit a rx8 5 speed gearbox to mk2 rs2000 clocks?
    3,248
    Mk2 RS2000 clocks are mechanical so this would be pointless for you!
