Results 1 to 20 of 20
Thread: seat bars
    Jan 2006
    sydney
    11
    seat bars
    hiya, iam considering putting in seat bars in my mk1.all the interior is out at the moment as i just replaced the front floors so its either now or never!!
    just wanting to find out some advantages/disadvatages of doing this..pics would be great aswell
    and whats the best way of working out the correct heights and angles? its for recaros.
    cheers
    Spanner Monkey Phil01825's Avatar
    Dec 2005
    East Sussex
    335
    Re: seat bars
    Quote Originally Posted by bundy View Post
    cheers
    Can anyone advise Bundy?
    Mar 2004
    Harlow, Essex
    14,285
    318
    Re: seat bars
    the best way or sorting it out on normal runners is to block the seat up with wood till its at a height your comfy with. then take measurements at the mounting hole lines, but basicly you need the front around 30-40mm higher than the rear, get a bar kit from prepfab as these use the sliding nuts type bars and take your time
    Jan 2006
    sydney
    11
    Re: seat bars
    thanks 4 the replys
    with the reinforcing plates do they get welded onto the inner sills and tunnel or do i cut out the sections and weld the plates in
    Mar 2004
    Harlow, Essex
    14,285
    318
    Re: seat bars
    weld over the top... drill a 6mm hole in one corner before doing it though as this allows the area behind to breathe
    Jan 2006
    sydney
    11
    Re: seat bars
    cheers Gary. yeh i was just concerned about trapping so much air between the plates but the breather hole makes perfect sense
    thanks
    Racer Decade Plus User Roger Miller's Avatar
    Jan 2003
    Australia, Adelaide, South Australia,
    2,897
    Re: seat bars
    Gary,
    I know welding all round is neatest, but is it not engineeringly [is that a word??] not sound due to metal structure changes just next to weld etc. Is this not one of the reasons we stitch weld seams ??
    PS round tube is the go.
    Attached Thumbnails Attached Thumbnails seatbars12.jpg‎
    seatbars15.jpg‎
    seatbars38.jpg‎
    seatrails_jpg.jpg‎
    seatbars40.jpg‎
    seatrails2.JPG‎
    Take it Easy....
    Roger Miller
    Works-Escorts = http://rsmotorsport.com.au/
    Mar 2004
    Harlow, Essex
    14,285
    318
    Re: seat bars
    Rules is Rules Roger, over here a continous seam weld is required.. as for the pros and cons of stitch or seam .. a stitch as many start points for fractures ..ie either end of the stitch.. over a 10" length that around 10 points where as a seam weld has no breaks so less starting ponts for fractures.
    Its a bit of a suck and see really as the uses and positions to do continuous welding or not and also experience.. you do it.. if it cracks you try it another way, if it cracks again you make the part better
    Apr 2006
    Auckland, NZ
    243
    Re: seat bars
    sorry to bring up an old thread, but I've bought some cobra classic bucket seats that came with some "universal mounts" that dont fit my car. I see what you have done in race cars but if my seats were to be fitted like that then there could be no access to my rear seats, which I still want as it is still a road car.
    Even if I mount them far forward straight into the floorpan(with strengthening plates etc) then it is still pretty impossible for passengers to get in because the seats are fixed back.
    How can I get around this? I'm thinking some kind of setup similar to the standard mk1 setup, but stronger. Any ideas?
    http://img211.imageshack.us/img211/7983/pete4as.jpg
    Mar 2004
    Harlow, Essex
    14,285
    318
    Re: seat bars
    You can get a universal seat subframe with a tilting mechanism in it ... try some of the seat manufactures over there to see if they do them.
    Jan 2003
    2,897
    Re: seat bars
    Chaps,
    What size is recommended for the tubing.
    EG. diameter and wall thickness ??
    Thank you
    Take it Easy....
    Roger Miller
    Jan 2003
    2,897
    Re: seat bars
    Well, ....got f#$k All input from you lot, so went my own way.
    Attached Thumbnails Attached Thumbnails RM-Seat-Mounts-18.JPG‎
    RM-Seat-Mounts-21.JPG‎
    RM-Seat-Mounts-23.JPG‎
    RM-Seat-Mounts-24.JPG‎
    Take it Easy....
    Roger Miller
    Jul 2005
    telford
    173
    Re: seat bars
    have you cut into the floor there to fit them
    also my end spreader plates are twise the size off them
    Clint's Avatar
    Jul 2001
    936,109
    Re: seat bars
    Motorsport Tools our sponsor do some nice seat mounting bar kits and quite cheap too
    Jan 2003
    2,897
    Re: seat bars
    Quote Originally Posted by kirk honda View Post
    Yes , mate, certainly looks like it
    Good on you for adding extra weight !
    The end plates even at 14 X twise the size, would envelope around the tubes,
    in a side impact, as there is very little strength in sills etc. Same deal at trans tunnel.
    Affixing tubes to floor [at chassis rails] also means a side impact, might not even convolute floor pan, providing a "cell" area for driver.
    Either way its a fair bit stronger/stiffer than further up images
    Take it Easy....
    Roger Miller
    Jul 2005
    telford
    173
    Re: seat bars
    i was only saying christ
    put your dummy back in
    Jan 2003
    2,897
    Re: seat bars
    And you haven't put crush prevention in tubes. How are you gonna get any tension on those bolts
    Take it Easy....
    Roger Miller
    Jul 2005
    telford
    173
    Re: seat bars
    good point mate will look into that thanks
    first 1 ive done so im learning as i go
  19. #19
    Jan 2003
    2,897
    Re: seat bars
    Whatcha cando is, find some tube, that seat bolts fit in, and drill out the upper side of your bars, to suit Outside Diameter. , of new tube.
    [Only drill through upper half of seat bar]
    Then you'll have to shape new tube to "fit" in this hole.
    Run some weld around top of hole, when fitted.
    Bit of grinding, should end up looking like factory made
    Attached Thumbnails Attached Thumbnails Seat-Mount-Mod-1.gif‎
    Take it Easy....
    Roger Miller
  20. #20
    Jul 2005
    telford
    173
    Re: seat bars
    thanks never really thought about it before you mentioned it
Similar Threads
  1. Seat Bars
    By bobb1 in forum The Technical Section
    Last Post: 25-09-2005, 20:01
  2. Door Bars
    By magic55 in forum The Technical Section
    Last Post: 18-06-2005, 19:21
  3. mk2 mexico seat bars
    By Mark_D in forum Restorations and Projects
    Last Post: 21-11-2004, 12:55
  4. Tramp bars
    By meXEco in forum General Car Banter
    Last Post: 10-10-2003, 22:57
  5. 3 Bars - Value?
    By Clint in forum Message Centre
    Last Post: 29-05-2003, 13:23
