Distributor - Which ??????
Right guys! Help needed again, Building a kit car, 2.0 pinto standard cam twin 45's.
What dizzy ??????????
Do i get a points? with or without vac
Do i get a kit? with ignition amp
Help needed !
Ta
Re: Distributor - Which ??????
I used this one when I was running a distributor, worked well and an easy install http://www.simonbbc.com/distributors...ic-distributor
maybe a daft question but does this need an ignition amp?
nope, just connect the two wires to the coil
