mk2 escort estate performance exhaust backbox wanted
i'm looking for a 2in bore sports backbox for my mk2 escort estate the normal saloon ones don't fit as the petrol tanks in the way, will also consider full systems thanks
Re: mk2 escort estate performance exhaust backbox wanted
Dont think you can get one of the shelf, mines a standard one that had the backbox cut and turned 90 degrees then re welded to clear the tank, think most are the same.
yes i think your right, i had a go myself and messed it up,hopefully someones got something decent i can just fit, thanks for the reply
I had this on my estate from Malta .................
![](http://uploads.turbosport.co.uk/getrempic3.php?url=http://i241.photobucket.com/albums/ff239/lynx2us/Cars%204%20Sale/Maltese%20Mk1%20Estate/15102009804.jpg)
Probably still got it on a shelf somewhere ?
I will sell you a full exhaust system off a mk 1 escort van that was on a x flow and it is 2" and a twin silencer system in stainless steel you will have to have it modded to fit your manifold though. PM me if your intrested.
i'm interested in the back box how much are you looking for and could you post?
thanks freddy but i think i might struggle getting that done
I have a barely used ashley rear silencer for a saloon if you are interested
thanks but my problem is turning it 90 degrees and getting it re-welded again and i messed mine up already i don't want to do another one cheers
If i knew exactly how it had to go i'd modify it for you
thanks thats good of you to offer, just found a new sportex system on ebay for £90 if i can find someone locally to modify it i might go for that cheers
