Hi Guys,
I have a massive clunk in my front end on the right on my MK II. When I go over a bump in the road or speed hump when the front wheels come under compression again there is a noice (clunk) that sounds like the shocker is loose in the strut. I pulled both struts over the weekend and made sure the gland nutsw are tightend and the shocks arenlt moving.
I am running shortened capri struts with coilovers, adjustable strut tops, adjustable TCA's, adjustable sway bar & anti dive kit.
As I don't have flared guards and the struts are so low I have had to do up the coil overs to their highest settings and I am thinking could this cause the knock.
I have gone over everything and am at a point of just saying fuck it and take it to a garage and throw money at the problem but I want to fix it myself.
What are some things that others suggest that may cause this loud clunking?
1. Loose steering rack
2. Steering arms fouling swaybar
3. Loose nut from TCA to strut
4. Spring coils compressing and makming a noise
It feels like the front end compresses over a bump then when the suspension loads up this is when the noise occurs.
Thanks in advance.
Matt
